Hugh Coleman Posted April 26, 2010 Share Posted April 26, 2010 Real nice Halifax Tony. Sounds superb with all four engines filling their boots. Congats! Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted April 26, 2010 Share Posted April 26, 2010 Yes it flew well Hugh Quote Link to comment Share on other sites More sharing options...
Foamie Dave Posted April 26, 2010 Share Posted April 26, 2010 Very tasty indeed !!! Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted April 27, 2010 Author Share Posted April 27, 2010 Can I ask what size engines were used? And other specs, such as wing span and weight? Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted April 27, 2010 Share Posted April 27, 2010 Yup, 104" span, 23lbs. The model is using 4 x .30 four-strokes but you could go a bit bigger than these. Quote Link to comment Share on other sites More sharing options...
A.A. Barry Posted April 27, 2010 Share Posted April 27, 2010 David, is this "special" instead of the W.W B Quote Link to comment Share on other sites More sharing options...
simon burch Posted April 27, 2010 Share Posted April 27, 2010 This is definitely on my list. Always wanted to build a multi, and this is a perfect size. Cheers, Simon Quote Link to comment Share on other sites More sharing options...
martyn sharp Posted May 7, 2010 Share Posted May 7, 2010 Is Tony going to be doing a electric alternative plan build plan pack i guess 4 *e-flite "46" or equivalent. that should be good Martyn Edited By martyn sharp on 07/05/2010 14:49:14 Quote Link to comment Share on other sites More sharing options...
Josip Vrandecic -Mes Posted May 7, 2010 Share Posted May 7, 2010 Hi Tony ! Not easy to make four i.c. ,should have the courage and knowledge..Bravo Maestro Quote Link to comment Share on other sites More sharing options...
A.A. Barry Posted May 7, 2010 Share Posted May 7, 2010 David, will there be cowls and canopy's available too???? A.A.Barry Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted May 8, 2010 Share Posted May 8, 2010 Yes Barry Quote Link to comment Share on other sites More sharing options...
A.A. Barry Posted May 8, 2010 Share Posted May 8, 2010 THanks, David, seeing there isn't going to be Whirlwind this year, I will make do with a Halifax instead that is after the Hornet I presume CNC parts will be available, only thing is the length of the box, for post, ???will the main spars be under 1050mm long A.A. Barry Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted May 17, 2010 Share Posted May 17, 2010 Plans etc. now on sale here. Quote Link to comment Share on other sites More sharing options...
