matt jarvis Posted May 5, 2010 Share Posted May 5, 2010 I need to know the best way forward connecting these bottom set of wings to the fuse,,I have built in spruce spars in to the wings and these spars insurt into adjoining holes in 1/8 balsa,with apoxy holding all together.Should I replace the 1/8 balsa area with spruce also to reinforce this join or is there a better way?The wings will be fitted after covering. Edited By matt jarvis on 05/05/2010 22:59:37Edited By matt jarvis on 05/05/2010 23:00:11 Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted May 5, 2010 Share Posted May 5, 2010 Hi Matt, what span and approx weight is the model? BEB Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted May 5, 2010 Share Posted May 5, 2010 OK - yes, it would help if I read the read title! Sorry The fixings look very small to me to be honest. I would suggest that rather than replace the 1/8th balsa root you face it with ply. Even then the spar inserts look short BEB Quote Link to comment Share on other sites More sharing options...
matt jarvis Posted May 6, 2010 Author Share Posted May 6, 2010 The weight hopefully will be between 900g /1000g with complete electric flight pack. Quote Link to comment Share on other sites More sharing options...
