Snorbitz Posted June 14, 2010 Share Posted June 14, 2010 I'm just in the process of fitting an Air Up/Down retract system and will at some stage need to pump up the system....i was just wondering if anyone had ever made an electric air pump system using say a car tyre inflator as apposed to a standard hand pump?. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted June 14, 2010 Share Posted June 14, 2010 One guy at our fielfd uses one and he is able to put the correct pressure in from its built in pressure guage.He just uses a couple of clips attached to the original cigarette lighter plug Quote Link to comment Share on other sites More sharing options...
Marko Posted June 14, 2010 Share Posted June 14, 2010 Hi Paul there are those type of pumps are around and they cost a lot more than a simple foot pump ?5 halfords!! Which is all l use for my hawk it works fine 80 psi gives me 5 ups Cheers .........mark ps it's also another thing you have to remember to charge !!!!! Quote Link to comment Share on other sites More sharing options...
Snorbitz Posted June 14, 2010 Author Share Posted June 14, 2010 Good point Mark....i've got an old foot pump with guage in the garage i'll have to dig it out and see if i can't adapt it to the filler pipe on the plane's system.Cheers Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted June 14, 2010 Share Posted June 14, 2010 Some guys use cycle pumps Quote Link to comment Share on other sites More sharing options...
Marko Posted June 14, 2010 Share Posted June 14, 2010 Hi Paul I've got a football needle valve with a short length of air pipe and then the screw on valve it works a treat ! Cheers mark Quote Link to comment Share on other sites More sharing options...
