Wot 4 Mk 2 Wing Bolt inserts/Sleeve for Wing Bolts
Hi All
We have a wot 4 mk2 artf with a 65 up front. I was looking for some inner wing inserts - washers - whatever they are called that are similar to the blackhorse twister inserts. They are plastic. Just want to stop the holes from getting elongated.
I have contacted tjd models and hobbystores with no success.
do you know what they are called or where I can locate some
thanks for your help
Tom
Hi Thomas,
I think I know what you mean, they are like a plastic tube that are an "outer" for the wing bolt.  I once had a model that came with them.
These outers are glued into the hole and like you say helps prevent any "enlarging" of the hole via constant vibration or whatever.
Cant say I have seen them commercially availiable but I have made my own in the past from some light ali tube from the local hobby shop, obviously you need them to be just wider than the bolt.  Cut them to fit and glue into the hole
Jobs a good un
Craig
