Boots Posted September 14, 2010 Share Posted September 14, 2010 I have just taken the rx ( Dynam R 5p ) from an r/c car and the aerial has been cut to about 2". Anyone have a good guess at how long it should be ?I know little about this tx and rx , it was taken out of an rtf plane and is 36Mhz and intended for the Australian market ( I am in Cyprus ) I have done some short range testing so far and it seems to perform correctly with both 35Mhz and the 36Mhz crystals. I have cross checked compatability with my present gear Hitec focus 6 TX and a jeti rex 7 rx and a micron kit rx and a sunupp su/r-6fm/ppm I realy need to put a suitable aerial on the dynam rx to conclude my range testing, it will be a valuble addtion to my r/c gear if it proves reliable Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted September 15, 2010 Share Posted September 15, 2010 hello boot's-if only it was that easy...you may have a different set of rule's/reg's for where you are.....but in the past i have heard read that it is not as easy as you describe.....ie the particular radio equip is specific for what it is installed in...you say a car.......i might be completly wrong...but i would hate to see you lose your model aircraft or even worse cause some 3rd party damage..... ken anderson...ne..1. Quote Link to comment Share on other sites More sharing options...
Boots Posted September 20, 2010 Author Share Posted September 20, 2010 It is designed for aircraft, a rated tx output of 0.8w and a range of 800m so I assume it is a full range and not "park fly"Just dicovered rx aerial should be 100cm, so it is now!I agree on frequency with it being 36Mhz, I willnot use 35mhz xtals, but this system was sold in cyprus so i will use it in cyprus !!! Quote Link to comment Share on other sites More sharing options...
