Huggy Posted September 24, 2010 Share Posted September 24, 2010 After making a start in RC with a Hobbyzone Cub, I thought I'd like something smaller for occasional use on calm days, on small fields or maybe indoors one day, and built the 27" mini version of the V-Tail trainer from Flying Wings. Having spent years playing with balsa, I must say, using chunks of foam was something different, but UHU Por and foam-friendly Cyano does make it easy and quick, doesn't it? Still working my way round actual radio and electronic installations, I was chuffed to bits when it all worked, and with very little servo movement - and once I'd sorted out how and what should be reversed ahem - it flew from the off and with it's teeny little outrunner motor is quite lively. And it bounces well! Not a bad little 'plane for fun flying, anyone built the bigger one? Any suggestions as to what might be a good step up from these two once I've got some hours in? Quote Link to comment Share on other sites More sharing options...
Tony Read 2 Posted September 27, 2010 Share Posted September 27, 2010 I still fly my larger V-tail, although I burnt out the original motor when I tried a 3-cell pack on it! Flying Wings now recommend a different motor, and that is the one I now use. I love flying it up until it becomes a spec in the sky and then gliding about searching for thermals. Get Loooong flying times this way. I went onto a Parkzone Trojan, although you might need a bit more space than a small field for this. Quote Link to comment Share on other sites More sharing options...
Huggy Posted September 27, 2010 Author Share Posted September 27, 2010 Cheers Tony. Been flying the little 'un today, so calm. 800ma battery lasts four or five flights if you don't go mad, total about 12 - 15 mins. Had some good flights out of a little free flighter with KP timer too, just the job. Like the look of the Parkzone Extra 300 can't seem to trace the Trojan. I like foam anyway, it b o u n c e s nicely Quote Link to comment Share on other sites More sharing options...
