Shaun Clarke Posted September 5, 2007 Share Posted September 5, 2007 I am very new to building having just aquired an unbuilt Olympian 40 Trainer with a Irvice 40 ABC engine from a friend. The wings are constructed from a ply frame, polystyrene & a veneer finish. The wing halves are joined by a large wooden dowel and require gluing. I have just brought some BSI 15 minute Epoxy...is this safe to use on the polystyrene & is it the correct adhesive for the job? Thanks. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted September 5, 2007 Share Posted September 5, 2007 it should be fine... most glues are ok on polystyrene EXCEPT CA ( cyano / superglue ) although you can get what is known as "foam friendly" cyano ...also known as odourless.Epoxy is better for many jobs anyway as it gives a little time to position and clamp things up before it cures. Quote Link to comment Share on other sites More sharing options...
Shaun Clarke Posted September 6, 2007 Author Share Posted September 6, 2007 Many thanks. Shaun Quote Link to comment Share on other sites More sharing options...
Allan Jordan Posted September 8, 2007 Share Posted September 8, 2007 Morning Timbo, I have been using B&Q own brand epoxy for a long time now and I have not had any problems. What do you use? Regards Allan J...TTFN Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted September 8, 2007 Share Posted September 8, 2007 I like either the flair "twinset" or the one that comes in the "matched pair syringes"For a really strong epoxy, I like Devcon. I also find myself using the gorilla glue a lot more these days, seems theres nothing this stuff wont stick and very well too, just not got the cure speed of epoxy of course. Quote Link to comment Share on other sites More sharing options...
