electrotor Posted October 29, 2010 Share Posted October 29, 2010 I too have one of these models and have enjoyed flying it. Whilst I would generally agree with Julian Beckett''s review I think it should have more than alluded to one of the fundamental flaws with this model. If you follow the instructions you will glue on the nose moulding/motor mount thus making it difficult to remove the motor. You may then think that you might be able to remove the motor via the battery hatch. That''s the second major flaw - the hatch is too narrow. What were Multiplex thinking about? On my model I reamed out the nose internally, reinforced it with thin ply doublers and glasscloth and made the nose/motor mount removable by using 2 screws and blind nuts. For what you get the airframe kit is rather expensive. For what you get the tuning kit is ridiculously expensive. I tried sourcing the motor elswhere but was not prepared to fork out more than £30 for a low power brushless motor with a 2mm diam. shaft (easily bent so you might want it removable). I ended up getting a much more powerful motor with a 3mm diam shaft for a third of the price. Again what were Multiplex thinking about? After the Twinstar I am somewhat disappointed with this model. It is not good value for money and has major design flaws.Edited By electrotor on 29/10/2010 16:49:26 Quote Link to comment Share on other sites More sharing options...
James M Posted October 29, 2010 Share Posted October 29, 2010 Hi electrotor What motor did you end up using ?? Quote Link to comment Share on other sites More sharing options...
electrotor Posted October 30, 2010 Author Share Posted October 30, 2010 Posted by James M on 29/10/2010 17:05:52: Hi electrotor What motor did you end up using ?? This one from Giantcod. Not only did I ream out the foam in the nose, but I rerouted the motor wires out and under, avoiding any possiblity of them rubbing against the motor. This possibility is mentioned in Julian's review. Here's a link to some build photos. Edited By electrotor on 30/10/2010 17:08:58Edited By Tim Mackey - Administrator on 30/10/2010 23:09:19 Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 30, 2010 Share Posted October 30, 2010 electrorotor - please use the correct method for links Quote Link to comment Share on other sites More sharing options...
electrotor Posted October 30, 2010 Author Share Posted October 30, 2010 Sorry Tim, each Forum seems to have it's own quirks and I didn't spot the link button. I'll remember for the next time. There's no edit button available for me to do it retrospectively though. BTW please get my name right.Edited By electrotor on 30/10/2010 22:59:28 Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 30, 2010 Share Posted October 30, 2010 Sorry about the name.Editing is time limited, and also forbidden once another post is made.I'll do your links for ya this time Quote Link to comment Share on other sites More sharing options...
James M Posted November 5, 2010 Share Posted November 5, 2010 Thanks for the info, electrotor, sorry for the delay been busy. Quote Link to comment Share on other sites More sharing options...
