Flanker . Posted February 11, 2011 Share Posted February 11, 2011 Hi all. I have just fitted a lovely 30 cc DLE to my YAK. (meant for a .60) It flies VERY nicely indeed thank you very much . Thing is the large petrol motor generates some vibration esp at low RPM. More vibes than a .91 Glo ? Maybe not but definitely more low frequency vibes. Now the whole shebang relies on the integrity of the little (new) Futaba switch mounted on the side of the fuz. OK I assume Futaba planned for out of balance props etc when they designed the thing and I have never had one fail but .... Are there "petrol" switches ? Would mounting in silicone and operating with a wire be good !? I would welcome any thoughts. Go well all, FEdited By Flanker . on 11/02/2011 14:51:25 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted February 11, 2011 Share Posted February 11, 2011 flanker--i've seen switches mounted on sandwiches made from two bit's of ply with some foam in the middle...also i seen them suspended inside model's with 'elastic' strap's/band's so they are floating and not hard mounted...and of course there are heavy duty switches avalable...check out what the 'large model people use....may suit your need's...... ken anderson ne...1. Quote Link to comment Share on other sites More sharing options...
001 Posted February 11, 2011 Share Posted February 11, 2011 Have a look at the Multiplex range of 'safety' switches, they do not depend on a mechanical make or break switch. Quote Link to comment Share on other sites More sharing options...
