Dean Posted February 23, 2011 Share Posted February 23, 2011 Hi, I have a 6 oz slec fuel tank that i want to fit in my Prangster, but to fit it i would need to trim the space for the tank, the thickness of the fuselage side where the tank sits is 13mm so to make the tank fit i would need to remove about 3mm of material from each side. Is this a good idea or could it weaken the structure to much? Thanks Dean Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted February 23, 2011 Share Posted February 23, 2011 I've done something similar in the past Dean. Once I'd finished hacking out the inside I lined it with 1/32" ply then a coat of fuel-proofer, tough as old boots! Quote Link to comment Share on other sites More sharing options...
Dean Posted February 23, 2011 Author Share Posted February 23, 2011 Thanks Doug, that sounds like a good idea, I'm off to my LMS this weekend to get fuel and other bits and bobs so will get some 1/32" ply too. Thanks Dean Quote Link to comment Share on other sites More sharing options...
flytilbroke Posted February 23, 2011 Share Posted February 23, 2011 I did something like that Dean. only I used a soldering iron, carefully. I found the trick was to only get the tip close enough to melt and shrink the surface you wish to "remove". The result was a hard tough coating. Quote Link to comment Share on other sites More sharing options...
Dean Posted February 23, 2011 Author Share Posted February 23, 2011 Thanks flytilbroke will have ago with my soldering iron tomorrow, that sounds a good way to remove the material and keeping it neat at the same time. Then i will fit the ply to the insides. Thanks chaps Quote Link to comment Share on other sites More sharing options...
Tim Morton Posted February 23, 2011 Share Posted February 23, 2011 Dean Suggest you put some 1/16" ply cheeks on either side of the fuselage too (before you wrap it in tape). Take it from the firewall to behind the rear dowel - much better strength and durability for very little weight. Drill the holes for the dowels etc. Quote Link to comment Share on other sites More sharing options...
