Tiger Tim Posted April 2, 2011 Share Posted April 2, 2011 I am converting this plan to electric flight,and am wondering how much incidence to set.I will be using 4 channels=throttle,rudder/elevator/aileron. Original plan has 5 degrees,I am thinkingto reduce it to about 2 degrees. Any comments suggestions ? Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted April 2, 2011 Share Posted April 2, 2011 Yeap, sounds a good plan to me TT. Two degrees should be plenty. You could even go a little lower depending on the wing section profile. If its very nearly symmetric stick with 2 degrees, if its tending more towards flat bottomed you could go to 1 degree - or even zero. BEB Quote Link to comment Share on other sites More sharing options...
Tiger Tim Posted April 7, 2011 Author Share Posted April 7, 2011 Many thanks BeB. Quote Link to comment Share on other sites More sharing options...
