Tony Read 2 Posted April 8, 2011 Share Posted April 8, 2011 This is a really dumb question, but what is the normal convention for the up/down retract switch on the DX6i, i.e. what would be the normal 'down' position? Thanks! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 8, 2011 Share Posted April 8, 2011 Not sure there is one - I often have the debate with others, on things like rate switches. I use a "positional bias" or in other words, if the switch is physically "UP" then my gear is up, and on rates, its likewise....if the switch is UP high, then so are the throws.With servo reverse function, the user can choose. Quote Link to comment Share on other sites More sharing options...
Tom Foreman Posted April 8, 2011 Share Posted April 8, 2011 I have all my switches set to up for take off mode, this makes it easier to flick all switches to up position before I switch on without any extra thinking required. In your case your gear would retract on switch down. Cheers Tom Edited By Tom Foreman on 08/04/2011 09:47:20 Quote Link to comment Share on other sites More sharing options...
Tony Read 2 Posted April 8, 2011 Author Share Posted April 8, 2011 Soooo, from the above Tim and Tom are opposite to each other? I must admit that I have set mine the same as Tims, i.e. flicking the switch back or 'up' would retract the undercart, but I can also see the merits in having a default mode as per Tom. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted April 8, 2011 Share Posted April 8, 2011 I use exactly the same logic as Tim, works for me but I've had "discussions" about it at the field with others who disagree. I like Toms default mode too. Thankfully my TX (DX8) will remind me at switch on if a switch is in a bad position. (assuming I set it up to). Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 8, 2011 Share Posted April 8, 2011 Posted by Tom Foreman on 08/04/2011 09:46:42: I have all my switches set to up for take off mode, this makes it easier to flick all switches to up position before I switch on without any extra thinking required. In your case your gear would retract on switch down. Cheers Tom Edited By Tom Foreman on 08/04/2011 09:47:20 Uh? If my gear switch is down, then my gear is down. Quote Link to comment Share on other sites More sharing options...
Tom Foreman Posted April 8, 2011 Share Posted April 8, 2011 Do all your other switches start in the down position or is just your retract switch, e.g. rate switches, mix switches? Tom Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 8, 2011 Share Posted April 8, 2011 TBH I dont normally bother with rates - I just set travel to the same in both positions, and tend to use loads of expo. On models that I do employ rates, then usually they are in the lower position to start, and I may throw in high rates as the flight progresses. Mix switches tend to be down - as this represents "normal" flight mode on my DX7It was your comment that "in your case your gear would retract on switch down" that I dont get? Quote Link to comment Share on other sites More sharing options...
