Geriatric Novice Posted August 2, 2011 Share Posted August 2, 2011 Following a crash, the only damage to my Power 46 (apart from a bent shaft) appears to be a chipped bearing in the top (outermost) race of the rotating can. Horizon Hobby say that E-Fight do not do spares, so I am on my own. Has anyone tried to change this bearing? If so where did you get the replacement from?In particular there are two races at the top of the can - do they both drift out from the back or is there a web inbetween? ie are the bearings pressed in from different sides? Many Thanks Paul Quote Link to comment Share on other sites More sharing options...
James40 Posted August 2, 2011 Share Posted August 2, 2011 You need either, One 6 x 15 x 5mm Bearing, or Two 6 x 12 x 4mm Bearings. SKF only do 6 x 19 x 6 here However, here's one from a UK company. Just visit Simply Bearings and type in the size youre looking for. Hope that helps? Quote Link to comment Share on other sites More sharing options...
James40 Posted August 2, 2011 Share Posted August 2, 2011 This is probably a better bearing for a motor sealed bearing . Quote Link to comment Share on other sites More sharing options...
Geriatric Novice Posted August 3, 2011 Author Share Posted August 3, 2011 Many thanks. I am on holiday at my son's in England at the moment. As soon as I get home to Scotland, I will have a go, and let you know how I got on. Paul. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted August 3, 2011 Share Posted August 3, 2011 Modelfixings do some small bearings....other than that type ball bearing suppliers into Google.....lots of on line suppliers. Or try a local bearing factors....if they don't have them in stock I'm sure they will be able to get you some in a day or two.... Quote Link to comment Share on other sites More sharing options...
Tony Fry Posted October 6, 2011 Share Posted October 6, 2011 smbbearings is the place to go Quote Link to comment Share on other sites More sharing options...
Geriatric Novice Posted October 25, 2011 Author Share Posted October 25, 2011 Tony,Many thanks. I two complete sets from simplybearings.co.uk for £20 excluding postage.Summer and holidays have got in the way, but I have removed the 2 smaller bearings - they tapped out easily through the back (larger bearing). Only the front bearing is showing signs of damage, but I will replace all three. There is a youtube on changing bearings on a Power 90. I looked at Bocca bearings, but couldn't find a UK supplier. http://www.youtube.com/watch?v=89B1b4nyIIA I will update once I have finished the job Quote Link to comment Share on other sites More sharing options...
