Conwy Soarer Posted August 21, 2011 Share Posted August 21, 2011 Using a Nokia 5800 with an angle measuring app, I was wondering whether it could be used as an incidence meter to check decalage on one of my new OD projects. Anyway here it is, works a treat, 40 minutes with some balsa and cyano. Quote Link to comment Share on other sites More sharing options...
kevin wild Posted August 22, 2011 Share Posted August 22, 2011 Fab Idea I tried this with my galaxy s, works great, you can calibrate the phone on the main wing then move it to the tail. as long as the model doesn't move you can get a true reading kevEdited By kevin wild on 22/08/2011 01:00:20 Quote Link to comment Share on other sites More sharing options...
twinstar Posted February 2, 2012 Share Posted February 2, 2012 For zero decalage: adjust the fuse so the LE and TE are the same height above a flat surface. = wing at zero incidence to flat surface, Then adjust the tail so that the LE and TE are the same height above the same flat surface Thus, tail is at zero incidence to flat surface too. Result is tail at zero angle relative to wing. Quote Link to comment Share on other sites More sharing options...
