steve watkin Posted February 11, 2012 Share Posted February 11, 2012 I'm going to build myself an electric version of an old 1960 single channel model that was originally powered by a Cox TD.020 (the powerful front induction one not the reed valve PeeWee) called Stubby. There is a view of it's little brother here. The layout is the same on both models.The model is a reasonably conventional high wing cabin model of 32" span. There is just one thing odd, and that is that the engine was mounted above the wing on a little pylon restricting the prop diameter to a max of about 4.5". Any suggestions as to a suitable motor/batt combination that will emulate the Cox and won't over power it? Quote Link to comment Share on other sites More sharing options...
PatMc Posted February 11, 2012 Share Posted February 11, 2012 Hi Steve, the TD .020 was rated as .055hp at 23000rpm using a 3 blade 3 1/8" prop. (A copy of the AM test report is in Martin Hepperle's web site) This power equates to about 41W. I flew a Graupner Lupo successfully indoors at 1/4 throttle using one of these on 2s lipos with a 7" prop. I think the Stubby is smaller than the Lupo so IMO a 4.5" prop & 3s lipo probably would give about the right power. An alternative might be this motor which is about the same weight & KV. A 450mAH 3s would probably be big enough but for the extra duration etc my choice would be this 800mAH 3s with a 10a ESC HTHPat.Edited By PatMc on 11/02/2012 23:02:13 Quote Link to comment Share on other sites More sharing options...
steve watkin Posted February 12, 2012 Author Share Posted February 12, 2012 Thanks Pat, I'll most likely go down the route of the CF2805 as it's cheap!!I do have a CF2812 which was given to me but i think that will be too much in both weight and power. Am I right?What would happen if I ran it on a 4.5" prop and a 2 cell LiPo, not enough thrust? Seems it would run at about 12000rpm with out a prop, so what could I expect with a 4 x 3 of similar?Just playing with ideas !! SW Quote Link to comment Share on other sites More sharing options...
PatMc Posted February 12, 2012 Share Posted February 12, 2012 Hi Steve, I think the 2812 uses the same fixing as the 2805 so you could try it first in the knowledge that it would only need a couple of turns of an alan key & the wiring to change over. For comparison, the nearest small motor I have with a similar KV is an old plain bell type that I've measured at 1400KV. It turned a small Gunther plastic (ex Twinstar) at 10700rpm, 8.3v (7nimhs) 4.8A, 40W & the same prop at 12700rpm, 9.8v (8 nimhs) 6.6A, 65W. Based on those figures I think you'd be well under 40W using 2s with a 1650KV motor & 4.5" prop. OTOH you have nothing to lose by trying it & as said you can easily change motors &/or go up to 3s. CheersPat. Quote Link to comment Share on other sites More sharing options...
