Steve Loates Posted December 8, 2007 Share Posted December 8, 2007 I have been flying a Honeybee King 2 for a few months now and have had some good fun, however, recently the tail has been quite a handful and no matter what trim I put in or how I adjust the gyro gain, it keeps doing its own thing. I can hover it for a few minutes quite happily and then for now reason it suddenly yaws round to the right. I can hold it steady but only with almost full deflection of the tail control. Any ideas? the gyro was found to be insecure after one such flight so has been resecured, but it is still doing it. What is the replacement interval for the tail rotor drive belt?Many thanks in advance Quote Link to comment Share on other sites More sharing options...
Alan B Posted December 22, 2007 Share Posted December 22, 2007 Hi SteveIf you hav'nt resolved the problem you can always check out my comments on Adrian Flanagans post below dated 04/10/07Al Quote Link to comment Share on other sites More sharing options...
Steve Loates Posted January 4, 2008 Author Share Posted January 4, 2008 Al, Sorry for not getting back to you sooner, but my broadband providers are crap (orange). I have re-fastened down the gyro and have adjusted the gain, however it has made no difference. I have had to attach a piece of plastic to the frame under the belt drive on the main shaft to try to stop it from coming off the pulley. Is it possible that the belt is a bit loose and if so should I extend the boom a fraction. Thanks Steve Quote Link to comment Share on other sites More sharing options...
Alan B Posted January 5, 2008 Share Posted January 5, 2008 Hi StevePossibly the boom might have loosened and the tension of the belt has pulled it in. Check that and try extending the boom as you say.Do the other checks as I mentioned above and see how you get on.Al Quote Link to comment Share on other sites More sharing options...
