Delta Whiskey Posted June 22, 2012 Share Posted June 22, 2012 Do I really have to buy a programming card to enable the brake setting or has anyone found a way around this? Quote Link to comment Share on other sites More sharing options...
slippyr4 Posted October 3, 2012 Share Posted October 3, 2012 You can program brake just fine from the transmitter. Are you having bother with it? Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted October 4, 2012 Author Share Posted October 4, 2012 Thanks for responding slippyr4 ! Yes, I cannot get the brake on. I've tried the normal proceedure for a different make esc I have, like moving the throttle to max while connecting battery, waiting for 2 bleeps them throttle to off, no joy ! Think I recall reading that on this esc a programming card is required.......? Quote Link to comment Share on other sites More sharing options...
slippyr4 Posted October 4, 2012 Share Posted October 4, 2012 The instructions for both the pentium and guard series of ESC from hobbywing, in all sizes, are the same. Although i've not got a 25A guard, i've got two in other sizes and programming has never been a problem. Here is a link to the instructions:- http://www.leaderhobby.com/img/menu/ESCManual.pdf If you can't get it into program mode, it could be that your throttle channel needs reversing? (make sure you take the prop off before you play with that though). Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted October 4, 2012 Share Posted October 4, 2012 I am very new to electric and when I started I got a program card. For me for less than £5.00 it was a bit of a no brainer. HOBBY WING CARD Kev Quote Link to comment Share on other sites More sharing options...
