JC Posted July 25, 2012 Share Posted July 25, 2012 Hi folks I have just put a 1500kv 380w inrunner in a new 2m glider. I'm using a 40 amp Skywalker esc. On starting the motor the motor twitches for a second or so then runs normally. Throttle response from then on is normal until I shut it down. On opening the throttle the same thing happens. I have programmed the esc with soft startup and low timing. I have very little knowledge of electric setups but have never had this before. The same thing occurs with 2 and 3 cell lipos. Any ideas? Futaba T7C 2.4 radio, FRSky rx. Thanks JC Quote Link to comment Share on other sites More sharing options...
GrahamC Posted July 25, 2012 Share Posted July 25, 2012 I'm no expert, but the first thing I would try is changing the timing to medium, and see if that is any better. It certainly won't harm to give it a try. Quote Link to comment Share on other sites More sharing options...
pete taylor Posted July 25, 2012 Share Posted July 25, 2012 I've had this a few times. Re-set the start up mode to normal and it normally cures it. Cheers Quote Link to comment Share on other sites More sharing options...
JC Posted July 27, 2012 Author Share Posted July 27, 2012 Thanks for the replies. I have set the startup to normal and timing to medium. It still twitches before running but it is better than before. Cheers JC Edited By JC on 27/07/2012 17:26:03 Quote Link to comment Share on other sites More sharing options...
