Gary Miles Posted August 9, 2012 Share Posted August 9, 2012 Hill I've just bought a crash damaged acrowot of ebay to repair as a bit of project with my kids over the school holidays.I've just built a new fuselage but the mid section of the wing has had an argument with a tree...and lost.but its damaged the veneer and not the foam .So could i just reveneer the damaged area,or do i have to replace the section of foam to?The damaged surface is about 3" in from the trailing edge & 4" wide.Is there a right &wrong way to repair this.Or could i even part re-rib it.Your help would be most appreciated. Quote Link to comment Share on other sites More sharing options...
Gary Miles Posted August 9, 2012 Author Share Posted August 9, 2012 Sorry ...I was in a hurry and forgot the ? mark ops Quote Link to comment Share on other sites More sharing options...
Djay Posted August 9, 2012 Share Posted August 9, 2012 Hello Gary. I would carefully cut away the damaged area of veneer to a uniform shape, and replace it with soft balsa roughly the same thickness. Glue it down with Gorilla glue or similar foaming type glue. then sand flush and recover the area. Check the foam after removing the damaged veneer, but the glue should foam up and repair any damage to the core. Darryl Quote Link to comment Share on other sites More sharing options...
Gary Miles Posted August 9, 2012 Author Share Posted August 9, 2012 Thanks darryl.....I'm of to by some balsa sheeting & gorilla glue then. Quote Link to comment Share on other sites More sharing options...
Simon B Posted August 9, 2012 Share Posted August 9, 2012 Make sure you hold down the wood while it dries though. Gorilla glue expands and will push it up if you're not careful. Quote Link to comment Share on other sites More sharing options...
Djay Posted August 9, 2012 Share Posted August 9, 2012 Gary, just a thin layer of gorilla glue, and hold the balsa down with clear tape to stop the wood lifting, as Simon has mentioned. Good luck. Darryl Quote Link to comment Share on other sites More sharing options...
