Pitch Gauge ?
Ian Rayne
Ian, One thing that post does not mention is that the flybar needs to be parallel to the tail boom throughout the set up. Sometimes it is possible to 'lock' the flybar by wedging a suitably sized allen key between the flybar cage and the top of the head or if funds allow you can buy a proper flybar locking tool for around £25.00. Normally if you get the pitch range on each blade set up to give the same pitch range the blade tracking will be spot on.
Hope this helps
Barry
