Barrie Dav 2 Posted October 25, 2012 Share Posted October 25, 2012 I'm having to fit battery and ESC into a pretty tight space. They fit OK but the balance connectors are too far apart to join up. Is there a limit on the length of the balance lead for the system to work correctly or will, say, a 10cm extension be alright? Quote Link to comment Share on other sites More sharing options...
Olly P Posted October 25, 2012 Share Posted October 25, 2012 Hi Barry I'm confused. Normally in flight your balance leads aren't connected to anything except an optional voltage monitor or telemetry unit? What are you planning to do to/with them? Olly Quote Link to comment Share on other sites More sharing options...
John Cole Posted October 25, 2012 Share Posted October 25, 2012 If you have a HobbyWIng Guard ESC (or similar) then the ESC LVC looks at each cell's voltage, not just the pack total voltage, and cuts the motor power when the lowest-voltage cell hits the limit you chose. For this, YES, you can use an extension to connect the 2 balance connectors. Quote Link to comment Share on other sites More sharing options...
Barrie Dav 2 Posted October 26, 2012 Author Share Posted October 26, 2012 Thanks for the gen John. Olly I have some Hobbywing Guard ESCs and they have a balance connector. Quote Link to comment Share on other sites More sharing options...
Olly P Posted October 26, 2012 Share Posted October 26, 2012 That now makes sense, thanks. Quote Link to comment Share on other sites More sharing options...
