Mark Millward Posted January 20, 2007 Share Posted January 20, 2007 Help! Did Alex Whittaker do an article on the Galahad with ailerons. I would realy like to build oneMark 3 DAYS LATER Hello IS THEIR ANYBODY OUT THERE Quote Link to comment Share on other sites More sharing options...
Graham Ashby 123 Posted January 25, 2007 Share Posted January 25, 2007 Hello Mark, just seen your message. You're quite right, Alex did pen an article on the Galahad in the February 2005 issue (pages 72 - 76). No ailerons fitted, just a feature on the Ben Buckle kit from a traditional build point of view. He did allude to an aileron wing version in the article but we haven't published anything since. Quote Link to comment Share on other sites More sharing options...
Matt Watts Posted March 16, 2007 Share Posted March 16, 2007 And are you hoping to/thinking of? Quote Link to comment Share on other sites More sharing options...
Patmac Posted March 17, 2007 Share Posted March 17, 2007 I built a Mercury original but modified with ailerons around 35 years ago.IIRC the dihedral was greatly reduced to around 2" each wing & the incidence was also reduced by half. Ailerons were full span 1.5" or 2" TE stock strip hinged on a 1/4" false TE & operated via torque rods. The ailerons were recessed into the wing outline. The rest of the model was more or less as per plan & the all parts nylon covered. Power was a Fox 25. A couple of guys I flew with at the time had similarly modded Galahads powered by OS 15s - the old loop scavenged version of course.They all flew beautifully, mine was predictably more spritely but the OS15 ones were adequately powered with better engine reliability. Pat. Quote Link to comment Share on other sites More sharing options...
