Gary Murphy 1 Posted November 29, 2012 Share Posted November 29, 2012 I am new to building and will soon have this issue.the closed loop wires for ele and rud 6 in all will need to exit the fuse.the plan shows them exiting holes in scrap balsa between stringers.In my build the angle at this point changes so there will be rubbing/ friction.do i need to line in holes at all and what is the best material for the lines.Thanks Quote Link to comment Share on other sites More sharing options...
Greybeard Posted November 29, 2012 Share Posted November 29, 2012 I use short pieces of small bore aluminium tubing and glue them in place to the fuslage. They can be shaped so that each end points in the direction of the wire. I have also used small bore plastic PTF tube. Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted November 29, 2012 Share Posted November 29, 2012 Gary I use the plastic snake inners as guides,they work very well The wire you need is plastic coated fishing trace,your local MS should stock it here are a couple of pics of my Tiger Moth closed loop system Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted November 29, 2012 Share Posted November 29, 2012 i also use snake inners however i plane them flush with the fus sides.... btw nice tiggi Jim Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted November 29, 2012 Share Posted November 29, 2012 Cheers Lee Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 29, 2012 Share Posted November 29, 2012 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Guest Posted November 30, 2012 Share Posted November 30, 2012 I use pieces of small plastic drinking straws john Edited By John Laird on 30/11/2012 09:07:52 Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted November 30, 2012 Share Posted November 30, 2012 I use whatever I find lying around, snake outer, straws, carbon tube cutoffs, even on rare occasions purpose made exit covers from SLEC, GS, Radio Active and the like. Airline issue coffee stirrers are currently favourite and they come in nice discreet pastel colours. Quote Link to comment Share on other sites More sharing options...
