Terry Honey Posted December 1, 2012 Share Posted December 1, 2012 I have recently purchased a VQ AT-6 Texan-Castrol.First inspection of contents, quality for the money seems excellent. However, one problem I found was that the engine cowl seemed too short. Instructions state that distance from the firewall to front of cowl should be 107mm. Problems is the cowl is only 90mm long. Thinking that an incorrect cowl had been supplied, I contacted Slough Radio Control Models to see if they could open another kit and measure the cowl for me. They were very obliging, but they did not have a kit in stock to check. Have any of RCM&E readers got one of these models that they can measure the cowl for me to see if the kit has been supplied with an incorrect cowl, or if it is just a common fault Thank you. Terry Honey Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted December 1, 2012 Share Posted December 1, 2012 it's not unusual to find that the manufaturers' instructions get things wrong, maybe they're not updated when the kit changes? Quote Link to comment Share on other sites More sharing options...
bouncebounce crunch Posted December 1, 2012 Share Posted December 1, 2012 G'day Terry is that the 46 size? i was just checking the manual online and the measurements are 110mm from firewall to face of the prop hub. Quote Link to comment Share on other sites More sharing options...
Terry Honey Posted December 1, 2012 Author Share Posted December 1, 2012 Thanks Bob. Think you're right. I thought it might have beem a misprint in the instructions. Trouble is the front of engine will 'stick out' quite a bit in front of the cowl. Even the engine mount is longer then the cowl. Quote Link to comment Share on other sites More sharing options...
Terry Honey Posted December 1, 2012 Author Share Posted December 1, 2012 Hi bouncebounce. Yes it is. Quote Link to comment Share on other sites More sharing options...
