J-Powers/Banana Hobby/Hobbyking P-51D EPO 1.55m(61")WS
Kelly
This is a review/ build of the Hobbyking Giant P-51D Mustang EPO.
I have done a sort of unboxing on Youtube and I will do another few videos as I progress with the build,
So I shall start with the manual
Nice and glossy with
Colour pictures, nice.
Bit of safe operating info like 'don't stick your finger in the prop when the motor is running'.
Apart from that nothing of use to help with the actual build,
It does give the location of the CoG but no info on the control throws???
Now the canopy, as seen in the video on Youtube came in a damaged condition.
If you enlarge the rather poor picture the damage is on the right hand side as viewed from the front, and half way along the top is a bubble type blister caused during the manufacture,
Blister a bit clearer (i hope).
You can see the cresing on the RH side also a join seam all the way along the centre line of the canopy.
Creasing in more detail,plus the paint flaking off on the frame.
Not very clear on the picture but a small slit half way along the windshield frame has been caused by the metal U/C legs packed inside the canopy as shown on the video.
So not a good start then.
I have tried to find a commercial replacement for the canopy,none are the same size( too short) based on the wingspan of the model.
I could make my own,but is it worth it? ,it's only a sport scale model .
If you want to see the unboxing video it is in the topic section , foam models on this forum.
To be contnued..........
Cut away part of the lower fuselarge tail section to gain access to the servos.
Tail wheel when retracted fouls the rudder servo arm.
One of the elevator servo arms is rubbing against the fuselarge side.
The lead from one of the main U/C legs is a very bad fit .
A few pics
the link to youtube will follow soon (loading) with more detail.
Ignore the bit about the tailwheel steering direction it is correct in the original position (I think)thinking
Checked out the motor and its mountings.
I had to add more thread to the prop adapter to enable a 2xblade prop to be fitted.
Esc with no name laugh
Two seperate plywood plates make up one mounting plate front and rear of firewall .four seperate plates in total ??
four aluminium tubes connect the two sets of mounting plates
All but two of the eight screws were found to be loose as well as two of the scews holding the motor to the mounting plate.
Re-attached the magnets holding the battery hatch in place
magnets originally glued to the foam with paint on the surface traces visable ?
paint removed and magnets glued into place with CA.
The gap between the spinner and the nose is rather large
Will have to close the gap with some balsa and filler. thinkingsmiley
  • 3 weeks later...
Used CA hinges and standard control horns/linkages on all the control surfaces
Tailwheel fitted
crush damage to flap inboard tip cured by soaking in hot water
I have decided to use the supplied servos they appear to function OK.
Video link soon.
Got the idea to make the wings removable here
**LINK**
The undercarriage units need to br replaced,poor quality fittings and grubscews failed when trying to attach the u/c legs. sad
If Hobbyking is following this thread a replacement cockpit canopy and the latest retract units would be nice laugh
Youtube link explains in a bit more detail
It will fly thinking eventually dont knowsmile o
Well the E-Flite retracts are due anytime now,a few thought coming to the end of this build.
Cost so far The model £68 plus £30 postage
Esc 60 Amp £40
Control horns and CA hinges £10
Retracts £58
Misc £15
Total £220 approx
Still good value compared to a H9 Mustang etc
Not included the cost of lipos but they serve multiple models anyway smiley.
It has been on sale for several years now and the foamy models i'm sure are well improved since then.
I may appear to moan a lot about this one but on the whole,if you are prepared to put a bit extra money and work you can have a decent model (i hope) in the end laugh
  • 3 weeks later...
  • 3 weeks later...
