david james 1 Posted January 17, 2013 Share Posted January 17, 2013 Altho I have a couple of electric gliders, this is my first foray into electric power. I had the maiden flight yesterday using the old 3S 3000mah batteries from the gliders. I think I need to buy a couple of new ones. If I bought some 4S, I could use them in a warbird, which is my next ambition. Do you think these would be likely to overpower the W4 or burn out the ESC? Quote Link to comment Share on other sites More sharing options...
WolstonFlyer Posted January 17, 2013 Share Posted January 17, 2013 Yes I think 4S will make the motor draw too much current and burn out the ESC and perhaps even the motor.You would have to fit a smaller prop to reduce the current draw for the motor's RPM at the higher voltage.I have seen several WOT4 Foam-e ESC's go up in smoke on 3S because the supplied ESC can be of varying quality and very marginal even though it is supposed to be rated at 40A.I have fitted a Hobbyking 60A Plush ESC to my WOT4 and it hardly gets warm. Quote Link to comment Share on other sites More sharing options...
Johnny Kirkham Posted January 17, 2013 Share Posted January 17, 2013 David check the writing on the ESC .......in my wot4 it says on the ESC 2-3 cell hope this helps Quote Link to comment Share on other sites More sharing options...
Allan Bowker Posted January 17, 2013 Share Posted January 17, 2013 David This reminds me a little of this thread where I pointed Johnny Kirkham to the WOT4 Foam-e thread, specifically to Simon Chambers posting on page 21 talking about fitting a 4S to his WOT. It seems that adding too much power to this model doesn't end well. Quote Link to comment Share on other sites More sharing options...
Stephen Horan Posted April 9, 2013 Share Posted April 9, 2013 Would a 2S 2200 be ok to put into the Foam-E Wot4/Acro Wot because I have a couple hanging around, or would it be lacking power??? Thanks. Quote Link to comment Share on other sites More sharing options...
