AlbertBallVC Posted February 12, 2013 Share Posted February 12, 2013 I have aquired a Skymaster biplane with a fibreglass fuselage that is in need of some repair work. The balsa wood fin post is coming unstuck from one side of the fibreglass fin; what would be the best method & glue type for re-sticking this. Also the gelcoat has been damaged in one or two places and has been ground back to solid material; there are a few extra small diameter drilled holes that need filling in, what would be the best type of filler to use on this. I intend to have the fuselage resprayed on completion. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted February 12, 2013 Share Posted February 12, 2013 This thread covers much the same topic.... Quote Link to comment Share on other sites More sharing options...
Ben B Posted February 12, 2013 Share Posted February 12, 2013 Epoxy will bond cured polyester to anything, polyester resin and such fillers (e.g. P45) will not bond onto cured epoxy glassfibre. So if you can work out (try smelling some drilled bits) or find out what glue was used in the lamination this would help. Unless you know I'd use epoxy to reglue the wood to GRP and use microballoons/epoxy as a filler. Obviously you will want to use a mask when sanding cured epoxy and microballoons... Quote Link to comment Share on other sites More sharing options...
AlbertBallVC Posted February 25, 2013 Author Share Posted February 25, 2013 Many thanks for the replies and advice, it was very helpful. Quote Link to comment Share on other sites More sharing options...
