Chris Perkins Posted February 15, 2008 Share Posted February 15, 2008 hi ive recently discovered that there are many video and audio cameras for rc planes. i have seen many reviews but wanted to know which one is favored by you and also which one is the best Value for money. thanks chris Quote Link to comment Share on other sites More sharing options...
Former Member Posted February 16, 2008 Share Posted February 16, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted February 16, 2008 Share Posted February 16, 2008 Hi Chris,Well I've only tried the FlyCamOne V2 and it has some very good points and a few bad ones!Good points:Decent resolution - 640 X 480 on video and 1280 X 1024 for still imagesUses a standard SD card to record on - up to 2GB cards are supported. This will give you longer duration than you are likely to need on one flight - see the problem with cold weather in the bad points though!Light - only 37gInexpensive - £45Bad points:Many people have reported short video durations in cold weather. I personally have found this, with the camera cutting off after about two minutes.Some have found poor synchronisation between audio and video and random colour shifts etc.Personally, I get the impression that the camera was put out before it has been truly "debugged". I think if the odd niggles can be sorted out then it's a very economical answer to in-flight video. You'll find several threads on here discussing the camera and there are plenty of video clips both here and on YouTube.Cheers,Tim. Quote Link to comment Share on other sites More sharing options...
Chris Perkins Posted February 17, 2008 Author Share Posted February 17, 2008 thanks for you views, its much appreciated Quote Link to comment Share on other sites More sharing options...
