Simon B Posted April 6, 2013 Share Posted April 6, 2013 I've had 3 'flights' with this and due to the very high wing loading its tendency to tip stall is something else. I've been doing some research online and it seems to be a common problem. Does anyone have any experience with this model and how to improve the problem? There doesn't appear to be much/any washout. I've repaired the firewall twice and getting a bit fed up. Much more of this and it's getting burnt...I've flown other tapered wing warbirds and had more success Edited By Simon B on 06/04/2013 23:15:55 Quote Link to comment Share on other sites More sharing options...
stuey Posted April 7, 2013 Share Posted April 7, 2013 If the ailerons are outboard ie near the tips rather than strip ailerons this might help. Adjust the aileron linkages so the aileron is sticking up a couple of mm each side, effectively giving a little washout. Might be worth a go! Quote Link to comment Share on other sites More sharing options...
Simon B Posted April 7, 2013 Author Share Posted April 7, 2013 Yeah that was next on my list of things to try. I had one proper flight with it, so it will fly, but i'm just concerned i'll lose it on a landing again. Fingers crossed! Edited By Simon B on 07/04/2013 10:45:06 Quote Link to comment Share on other sites More sharing options...
