Mike Hardy Posted April 15, 2013 Share Posted April 15, 2013 Hi just purchased the motor from HobbyKing whilst the motor shaft dia is quoted the prop adaptor info is not given I am sure someone on here will know. Mike. Quote Link to comment Share on other sites More sharing options...
Pete B Posted April 15, 2013 Share Posted April 15, 2013 With a shaft diameter of 5mm, the collet-type adapter shaft is probably going to be 8mm diameter, with an M8 nut. The 'bolt-on' propshaft will probably be the same. I can't be certain but I've got one somewhere - if I find it I'll let you know for sure! Pete ps Having said all that, if this is the motor, a read through the discussion section lower down the page dated 3/17/2012 quotes both prop adapter and propshaft as being M6 - might be best to wait until it arrives and check it for yourself.... Edited By Pete B - Moderator on 15/04/2013 23:06:54 Quote Link to comment Share on other sites More sharing options...
Mike Hardy Posted April 16, 2013 Author Share Posted April 16, 2013 Thanks Pete, Yes I think it is M6, just measured across the flats of the nut which is 10mm. It would be helpful if this info was given in the spec. Mike Quote Link to comment Share on other sites More sharing options...
