Fingerless Posted May 14, 2013 Share Posted May 14, 2013 I made the mistake of taking the connectors apart to get the wing on now i cant remember where the leads get connected to, there just so many of them has anyone got a simple guide for an Old Codger, thanks. Quote Link to comment Share on other sites More sharing options...
GrahamC Posted May 14, 2013 Share Posted May 14, 2013 Just plug them in one at at a time to one channel on your transmitter - you should be able to work out which connector goes to which servo. If you have a servo tester even better. I take it you have... Flaps, ailerons and retracts? ... And looking at it.. Is there maybe a sequencer there? The black thing wrapped in heat shrink? More information might help Edited By GrahamC on 14/05/2013 22:08:45 Quote Link to comment Share on other sites More sharing options...
Fingerless Posted May 15, 2013 Author Share Posted May 15, 2013 There are ones for landing lights, the doors on the undercarriage, the wheels another two, ones for split flaps as well, cant figure out where they all go, i may do away with the door and light connections i can get it to work then, the sequencer i wont use, when i plug it in it wont work, what i really need is someone who has this model. Quote Link to comment Share on other sites More sharing options...
Tony Read 2 Posted June 7, 2013 Share Posted June 7, 2013 Hi, you describe it as a Hobbyking 190, but in your vid you say its a Hobbyzone. Assuming its the Hobbyking plane I have had a look under 'files' on the product listing and there is nothing there. If it was me I would do as Graham says or post on the HK 'discussions' thread for this model, I'm sure someone will be able to help. Quote Link to comment Share on other sites More sharing options...
