J Myers III Posted July 27, 2013 Share Posted July 27, 2013 Hi all! I'd like to know if a JETiger set-up would be compatible with a new T-45 kit I ordered. In my JETiger I used a Turnigy nano-tech 1300mah 3S 25~50C Lipo Pack with the stock 30 amp esc, stock 64mm 6 bladed edf unit and the stock 4000kv brushless inrunner motor. I plan to transfer the motor, battery and the esc into the T-45 kit when it comes, however it uses a 5 bladed 64mm edf unit, will there be any problems? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Ady Hayward Posted July 29, 2013 Share Posted July 29, 2013 Hi, I would expect there to be little difference in flight performance between the two fan units. Just make sure that if the fan units are a different length that the airflow is not disrupted in front of the fan or at the rear where there may be gaps. Make sure that anything done in front of the fan is secure and cannot get sucked through. Adrian Quote Link to comment Share on other sites More sharing options...
Ade Eades (Eadsie) Posted August 9, 2013 Share Posted August 9, 2013 Posted by J Myers III on 27/07/2013 15:19:10: Hi all! I'd like to know if a JETiger set-up would be compatible with a new T-45 kit I ordered. In my JETiger I used a Turnigy nano-tech 1300mah 3S 25~50C Lipo Pack with the stock 30 amp esc, stock 64mm 6 bladed edf unit and the stock 4000kv brushless inrunner motor. I plan to transfer the motor, battery and the esc into the T-45 kit when it comes, however it uses a 5 bladed 64mm edf unit, will there be any problems? Thanks in advance! Hi Bud, i'm going to do the same with my electronics.....(as you know) i bought a T-45 yesterday.....my question is will my 2200mah batt's be ok or too heavy? sorry to butt-in your post, Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted August 9, 2013 Share Posted August 9, 2013 Looking on the website, it says a 2200 mah 3s battery is required, so a 2200 mah 3s will be good, A smaller battery will probably need some nose weight adding if there isn't enough room to move it forward to achieve the correct c of g, and will give a shorter flight time than a 2200mah battery. Quote Link to comment Share on other sites More sharing options...
J Myers III Posted August 9, 2013 Author Share Posted August 9, 2013 Posted by ADRIAN EADES on 09/08/2013 06:59:37: Posted by J Myers III on 27/07/2013 15:19:10: Hi all! I'd like to know if a JETiger set-up would be compatible with a new T-45 kit I ordered. In my JETiger I used a Turnigy nano-tech 1300mah 3S 25~50C Lipo Pack with the stock 30 amp esc, stock 64mm 6 bladed edf unit and the stock 4000kv brushless inrunner motor. I plan to transfer the motor, battery and the esc into the T-45 kit when it comes, however it uses a 5 bladed 64mm edf unit, will there be any problems? Thanks in advance! Hi Bud, i'm going to do the same with my electronics.....(as you know) i bought a T-45 yesterday.....my question is will my 2200mah batt's be ok or too heavy? sorry to butt-in your post, A 2200 will be all good. However this will pull 31 amps, just make sure your ESC is up to it Quote Link to comment Share on other sites More sharing options...
Ade Eades (Eadsie) Posted August 30, 2013 Share Posted August 30, 2013 Hi How is your set-up going? i maidened it and myself last night lol.....Brilliant, no puffy strained batteries, ESC fine, just bent the nose, nothing i can't fix. this jet is superb, cruises on half throttle, and really picks it's skirt up and shifts when required to do so. I hope you get yours sorted. The 2.2maH 25C 3c batteries are just sublime....i had to push the batt as far back as it would possibly go, that meant removing the thin 'Ply' battery tray....no Biggie though....TBH if the Ply batt tray was in there the damage would most deffinately been worse so quite happy there. Regards Ade. Quote Link to comment Share on other sites More sharing options...
J Myers III Posted August 30, 2013 Author Share Posted August 30, 2013 I still haven't touched mine... I really need to though, i think I'll wait until I order some 2.2mah's Quote Link to comment Share on other sites More sharing options...
Ade Eades (Eadsie) Posted August 30, 2013 Share Posted August 30, 2013 good idea, you will need to remove the ply battery holder plate to get the battery right back as far as possible, it kinda goes in at an upward angle if you know what i mean. the C of G is perfect. not that i know too much about it but it flies so true and dialed-in. I use 2.200maH 25C Turnigy Batteries, the one i used came out the plane after 4 mins of various throttle 'Cold' i'm using a E-Flyte 35A ESC and a 4,500 outrunner brushless Motor Edited By ADRIAN EADES on 30/08/2013 22:54:17 Quote Link to comment Share on other sites More sharing options...
J Myers III Posted September 1, 2013 Author Share Posted September 1, 2013 Yeah I have a 4600kv outrunner so I will be getting either a 35A or a 40A esc, and thanks for the advice! Quote Link to comment Share on other sites More sharing options...
