Russ P Posted September 7, 2013 Share Posted September 7, 2013 I've read in various articles where wing mounted servos are covered in shrink wrap and then glued into position. What type of shrink is used? Quote Link to comment Share on other sites More sharing options...
Jamie sawyer Posted September 7, 2013 Share Posted September 7, 2013 You can get up to 50mm heat shrink wrap on ebay. That might be big enough to fit a mini servo. I personally wrap the servo first in electrical take and glue it in place. Its just as secure. Jamie Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted September 7, 2013 Share Posted September 7, 2013 Masking tape is often used too Russ....the idea of the tape is to allow it to be removed taking the glue with it & leaving the servo case clean & fresh & ready to be glued in again..... Cleanliness is next to Godliness here.....remove all traces of dust & grease.... Quote Link to comment Share on other sites More sharing options...
