Depron Daz Posted October 30, 2013 Share Posted October 30, 2013 Depron does have a grain, so I suggest cutting some small squares from a sheet and marking orientation marks in order to find the grain before you start bending. Get it the wrong way and it will crease, get it the right way and it won't, unless you go too mad! Slight creases can be sanded out as it is 3mm thick, and you can get quite jiggy with it before it starts to suffer weakness. Quote Link to comment Share on other sites More sharing options...
Paul McCaughey Posted November 4, 2013 Share Posted November 4, 2013 a read of this thread will show you some of the great techniques being used on 1mm/2mm depron for indoor modes. **LINK** Quote Link to comment Share on other sites More sharing options...
john picton Posted November 4, 2013 Author Share Posted November 4, 2013 thanks Paul, I found this most rewarding, I have had some success forming depron will post photos soon .regards John Quote Link to comment Share on other sites More sharing options...
john picton Posted November 7, 2013 Author Share Posted November 7, 2013 Quote Link to comment Share on other sites More sharing options...
john picton Posted November 7, 2013 Author Share Posted November 7, 2013 The first two photos are first attempt with depron, an 18inch Frog Redwing electric powered. The second photos are of a Pistacio model Watt Money plan of Oro-Hume a single seat plane. Both models are yet to be tested in flight. I have nearly mastered the art of 'moulding depron' thanks to all you guys Quote Link to comment Share on other sites More sharing options...
Electriflier Posted November 7, 2013 Share Posted November 7, 2013 Nice work john! Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted November 7, 2013 Share Posted November 7, 2013 That looks nice John , will it be free flight and have you weighed it yet ? . Quote Link to comment Share on other sites More sharing options...
john picton Posted November 8, 2013 Author Share Posted November 8, 2013 Hi Stephen, both are free flight, the Redwing weight is 34g, a bit heavy as I was not sure how strong the Depron would be so it has been strengthened with balsa, weight including Motor, Capacitor and switch ect . The Pistacio all up weighs in at 7g, have tried flying in the front room with some success, think it will fly well in a large hall, will find out on the 24th. Electrifiier, Thanks for the comment. regards to all John Quote Link to comment Share on other sites More sharing options...
Paul McCaughey Posted November 17, 2013 Share Posted November 17, 2013 They look good. Did you use 1mm depron? If so where did you source it? Looking to get some but not sure where is best to get it. Ta Quote Link to comment Share on other sites More sharing options...
john picton Posted November 26, 2013 Author Share Posted November 26, 2013 Hi u all, The Depron REDWING flew right of the building board like a dream, powered by a 10f Capacitor I had several flights of about 60 seconds brilliant, I now intend to build a proper model to fly. After my last posting I built an own designed model with a 20 inch span and with the same set up it also flew like a dream, will post photos soon Quote Link to comment Share on other sites More sharing options...
john picton Posted November 26, 2013 Author Share Posted November 26, 2013 Quote Link to comment Share on other sites More sharing options...
