lightning 759 Posted September 18, 2016 Share Posted September 18, 2016 did this project get any further ? andy Quote Link to comment Share on other sites More sharing options...
Peter Curran 1 Posted October 25, 2016 Author Share Posted October 25, 2016 AndyActually I have restarted this weekend gone. I will post pictures of the wing restart tonight Quote Link to comment Share on other sites More sharing options...
Peter Curran 1 Posted January 1, 2017 Author Share Posted January 1, 2017 It has been way too long since my last update.........Feb 2015.... as it is now January 2017 quick update before I start the pictures... Moved to Canberra in Jan 16... as expected the removalists managed to break the wing tip off. This required a new wing (read that as too many errors in the first one).. Quote Link to comment Share on other sites More sharing options...
Peter Curran 1 Posted January 1, 2017 Author Share Posted January 1, 2017 Here is the old wing with the broken section removed and sitting in the bin covered the building board with cling wrap, bottom spar clamped to the board, ribs cut out and ready to glue center rib glued and braced, retract mounts assembled and glued into position all ribs in glued in place, top spar fitted, now cutting out and fitting the false leading edge and trailing edges wing assembled, top sheet fitted and rear spars fitted second half of the wing has been completed. both sides attached. Now the retracts have been fitted, and siting the servos for the flaps and ailerons the linkages will be RDS to keep the linkages hidden within the wing and streamlined (looks good too) Now to work on the gear doors, build the flaps and ailerons. Sheet the bottom of the wing... before getting started on the fuselage Edited By Peter Curran 1 on 01/01/2017 10:53:18 Quote Link to comment Share on other sites More sharing options...
