Eric Hartley Posted February 20, 2014 Share Posted February 20, 2014 Hi I've been using a KK2 board on a quadcopter and was wondering if it would be ok on a 450 sized helicopter? Has anyone tried one and if so what about the set up? Incidentally the heli. is FBL. Quote Link to comment Share on other sites More sharing options...
Bandit Posted February 20, 2014 Share Posted February 20, 2014 No Quote Link to comment Share on other sites More sharing options...
Eric Hartley Posted February 20, 2014 Author Share Posted February 20, 2014 Hi In that case What about the Beast x v3 or Align 3GX MRS? I have tried to research on the web and views seem divided most coming out in favour of the Beast x. Bearing in mind however I have the Futaba 14SG Tx the Align would seem to be a logical choice as it incorporates a Futaba compatible receiver. Has anyone advice on this matter or indeed alternative FBL control systems? Quote Link to comment Share on other sites More sharing options...
Colin Bernard Posted February 20, 2014 Share Posted February 20, 2014 Eric, It's a totally different method of control with heli's irrespective of whether or not it has a flybar. With multirotors you are essentially controlling it through the balance of thrust and torque from 4 or more motors, each doing the same job. With a heli you have one main rotor controlling direction, height and speed and the tail rotor controlling yaw. The two are mutually exclusive as far as sharing control technology. Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted February 20, 2014 Share Posted February 20, 2014 I had no luck with a regular Align 3Gx unit in my T-Rex 550 -- even sent it back for checking because I was convinced it was faulty. I then got a MicroBeast, and was able to fly it straight out of the box, without having to alter/adjust anything on the heli at all. Quote Link to comment Share on other sites More sharing options...
Robin Kearney Posted February 20, 2014 Share Posted February 20, 2014 Eric, have a look at the Ardupilot APM boards, I use one in a Quad, but I believe they support helictopers too. r. Quote Link to comment Share on other sites More sharing options...
