electrotor Posted March 15, 2008 Share Posted March 15, 2008 Digifleet use a 5 pin 180 degree DIN connector.I don't know if the Omega will work with Reflex.For connection details use this link http://www.customelectronics.co.uk/fmstx.htm and scroll to the bottom of the page. Quote Link to comment Share on other sites More sharing options...
Jamie Payne Posted April 21, 2008 Share Posted April 21, 2008 Hi I am hoping that you can help me save my fleet omega 7 Pro from the scrap heap! It has developed a fault and checks with an oscilloscope seem to make me suspect thatthe microcomputer a PIC16C64A has been corrupted I can replace this IC at a reasonable cost but would need the machine code to program the new IC any help on this would be of great help I no I could buy a new system but maybe someone could help . Quote Link to comment Share on other sites More sharing options...
electrotor Posted April 29, 2008 Share Posted April 29, 2008 It is very doubtful if the original machine code is still available anywhere. Probably Lippeatts should have it, having bought out Digifleet on the late Dereks retirement. However they seem to have gone to ground.I have noticed a couple of Omegas for sale on Ebay recently, one working, the other not. Mine works fine although a little fiddly to programme until you get the hang of it.Sorry I couldn't help more. Have you tried other forums? Eric Quote Link to comment Share on other sites More sharing options...
Chris Dowsett Posted April 30, 2008 Share Posted April 30, 2008 Thanks Flanker (see) ...build up of filth around the big main chip on the circuit board, cleaned it of with alcohol and all was well. Took David's advice and went into 2.5GHz, however just taken a look at my Fleet TX. You were right but on mine the filth is corrosion. All along the bottom edge of the main board.TX is working now but recommend everyone has a look at theirs just in case. The copper cladding may need cleaning and lacquering. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted April 30, 2008 Author Share Posted April 30, 2008 2.5 GHz Chris ? Quote Link to comment Share on other sites More sharing options...
Chris Dowsett Posted May 1, 2008 Share Posted May 1, 2008 Typing error David! Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted May 1, 2008 Author Share Posted May 1, 2008 I thought you had a new waveband all to yourself there Quote Link to comment Share on other sites More sharing options...
Jamie Payne Posted May 5, 2008 Share Posted May 5, 2008 Many thanks for the advice I am now on plan B writing my own code for the microcontroller I will probably add an lcd ,as you said the leds are a bit confusing regards Jamie. Quote Link to comment Share on other sites More sharing options...
