Terence Lynock Posted April 19, 2008 Share Posted April 19, 2008 Found some interesting stuff that is dirt cheap but supplier says you cant glue it, it is about 6mm thick and like corrugated cardboard but square channels and made of thin Polypropylene.I can get an 8' x 4' sheet for less than a tenner and it could be very useful for large wing ribs and bulkheads but need to find a glue that will actually stick to the stuff, anybody got any ideas dudes?, regards Terry Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 19, 2008 Share Posted April 19, 2008 Is this not correx board ? If so, the PU ( gorilla etc ) works fine if you roughen the surface slightly first. Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted April 19, 2008 Author Share Posted April 19, 2008 It may be Correx I dont know, it is used for making shop signs by the company and the off-cuts I have do not have a name or anything marked on them, it appears to be pretty tough stuff so may do some experimenting with it, regards, Terry Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted April 19, 2008 Share Posted April 19, 2008 I have used this stuff and glued it with thick CA just fine. I sanded the surface first to clean and roughen it. I even stuck the fin on glued end on to the tail plane with a doubler each side. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 19, 2008 Share Posted April 19, 2008 It definately souds like correx to me - estate agents use it for their signs -common enough stuff. Some peeps call it "twin-wall". I made replacement winglets for my GP Slinger with it, and stuck some fixings to it with PU - no probs.MUGI ( great models and super cheap too ) use contact adhesive like EVO stick, take a look HERE As we say.... ( morning Bruce ) just roughen it slightly first then PU or thick CA. UHU POR may work too ?? Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted April 19, 2008 Author Share Posted April 19, 2008 May well play with the stuff and see just what I can do with it, not sure how it compares to Balsa but there cant be that much difference and it is a lot stronger - now my only problem is we are packing to mve house and all my glues are in a box thats in a bigger box somewhere among about 30 other boxes that all look the same because they came from Morrisons supermarket........oh bugger, thanks chaps, Terry Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted April 19, 2008 Share Posted April 19, 2008 Morning Timbo keep up the good work! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 19, 2008 Share Posted April 19, 2008 I am off to play now...cold and a strong wind in almost the righ direction means an hour or two on the big rock, good opportunity to try out my new toy ( eagle tree onboard data logger with altimeter ) then back home for a nice hot chocolate and sticky bun before back to work on the latest project (s) in the workshop....ah the joys of early retirement, every day is like the weekend - no - wait - it IS the weekend ...see what I mean Quote Link to comment Share on other sites More sharing options...
iawnski Posted April 19, 2008 Share Posted April 19, 2008 looks like ive missed them sticky buns again tim /1 week to go and we will be up there/how did the new toy go(altitude please)) cu soon iawnski Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted April 19, 2008 Author Share Posted April 19, 2008 wait - it IS the weekend ...see what I meanYeh....and wot have I been doing? bunging a thick coat of bitumen on the shed roof then pruning a bloomin plum tree back up a ladder in a cold wind, got to get all the little jobs done so we can get this place saleable, mind you I had the plans for a Mike Smart 'Raven 3m' arrive this morning and it really looks different, more a piece of modern art than a glider.It has three wing options but I may add a fourth with extended tips by making the tips of the gull wing removable so I can plug the extensions in, regards, Terry Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 19, 2008 Share Posted April 19, 2008 Hi Kevin ( Iawnski) the altimeter seems to read a little erratic, and I think will need some more calibrating before it is accurate. I also need to play a bit more with the software...but the whole micrologger gizmo is pretty cool - mainly for us leccy flyers as it can capture and store a myriad of info such as battery perfirmance, maximum current draw, sevo current, and rpm. Add on sensors can also be bought which allow measurement of airpeed, temperatures, and even a GPS syestem to dispaly the models exact position relevant to the pilot, and play it back via google earth or similar. Fun toy..... but way off topic email closer to the time if you plan to do the Orme, and I will, as usual, join you guys for some fun Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 19, 2008 Share Posted April 19, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted April 19, 2008 Author Share Posted April 19, 2008 and even a GPS syestem to dispaly the models exact position relevant to the pilot, I always know where my model is.............nose down and two feet deep in a plowed field........... regards, Terry Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 19, 2008 Share Posted April 19, 2008 Quote Link to comment Share on other sites More sharing options...
iawnski Posted April 19, 2008 Share Posted April 19, 2008 will b in touch Quote Link to comment Share on other sites More sharing options...
Alan Davis Posted April 20, 2008 Share Posted April 20, 2008 Hi allI'm new to this forum and do not know anyone at all yet. I have interests in vintage control line, may be because I am vintage myself. any other controle liners out there? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 20, 2008 Share Posted April 20, 2008 Hi Alan and welcome...I suggest you start of with a short post in the newbie section, introducing yourself. Posting an intro, on a subject completely un-connected with the thread will get little response, and is actually known as "hi-jacking" in forum speak ! Dont worry though..its all part of the learning curve, and we dont bite on here. ( well not often anyway )...PS How's Steven ? Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 20, 2008 Share Posted April 20, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 20, 2008 Share Posted April 20, 2008 Fry-ed actually! Quote Link to comment Share on other sites More sharing options...
