Stevo Posted June 1, 2014 Share Posted June 1, 2014 Hi all. Here's a ... Now, all you leccy peoples.... Whats a good alternative... Its 850kv I need a bit more sparkle but not 3D! It has a 5mm shaft which is nice and strong, but if it noses over that bell housing shifts backwards and jams on the chassis - as mine has So.. any suggestions? Edited By Stevo on 01/06/2014 18:48:02 Quote Link to comment Share on other sites More sharing options...
JAMES LEE 1 Posted June 3, 2014 Share Posted June 3, 2014 Hello there. I currently fly a hobbyzone super cub- super xxx. It has a turnigy aerodrive 3536, i think 1200 rpm/volt,9x6 original prop. 60a esc. IMO performance from this motor is outstanding. As plane is now nearing retirement, i have purchased a riot, which i have not flown yet, however, motor looks to be puny by comparison, so i am interested to hear you are looking for more 'sparkle'. whatever my supercub lacks- it is certainly not sparkle. As i feel first impressions have a great effect on future satisfaction, my dilema is do i fly riot as is, transfer motor and prop from sc to riot (have not yet looked into space available) or like you, find a suitable motor with more 'sparkle'. While i have still not flown sc at wot, i am now accustomed to takeoff in 3ft, or less. I am supprised that you are not innundated with workable solutions from tested alternatives. I can't help, yet, but will watch with interest. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted June 3, 2014 Share Posted June 3, 2014 Here's a cut n paste from another forum. Apparently the designers words:- "just a little tip on the Riot, the model has been designed to be played with, out of the box it is set to be almost a trainer but with increasing the throws it becomes a very advanced trainer / sports hack, then if you wish you can remove the cowl ( two screw ) and you will find a steel weight which can be removed. when this is removed the CG will go back around 10-15mm which will then suit the more aggressive style. now for more fun and power you can mess with the power set up, we have fitted a 40 amp ESC so that you can if you wish use a 4 cell pack. if you do this you need to drop the propeller to a 10 x 5/6 and then even more power will be at your finger tips. Quote Link to comment Share on other sites More sharing options...
Stevo Posted June 5, 2014 Author Share Posted June 5, 2014 I broke the prop on landing - it simply nosed over at walking pace. When I looked at the prop it had snapped - and when I looked closer, the prop (the stock one) was full of air holes. Replaced with a 10x8 and it flew much better.= bu flight imes are 5-6m on a 2200maH Lipo.. James you may be interested in my other post regards the Riot I think in short if it had been built correctly and was a bit lighter I would be more enthusiatic. WOT4 Foam-e next time. Thanks for the tip Chris... Doesn't mention an alternative... Just wanted to see if anyone else had done anything. Quote Link to comment Share on other sites More sharing options...
andyh Posted June 8, 2014 Share Posted June 8, 2014 I use one of these in my WOT4 foam-e with an 11x7 or 11x8 prop: **LINK** stacks of power, unlimited vertical & would undoubtedly prop-hang (if I was able to). I get about 8mins off a 3s 2200mAh pack. & replacement prop-shafts available for 85p! Quote Link to comment Share on other sites More sharing options...
adrian lawrence 1 Posted June 8, 2014 Share Posted June 8, 2014 How abut this **LINK** Quote Link to comment Share on other sites More sharing options...
David... Posted June 8, 2014 Share Posted June 8, 2014 I replaced my Riot motor with the Hobbyking 4010 820kv 'donkey' brand, it seems to be exactly the same motor to me. I use 3S and have it turning a 12x6 it gives easy vertical performance and is a lot cheaper than the UK variant, only problem is waiting for it to arrive. Flight times are 12-mins of moderate/ mixed flight with a 2200mA battery. Edited By David... on 08/06/2014 07:54:38 Quote Link to comment Share on other sites More sharing options...
David Jacobs Posted January 23, 2015 Share Posted January 23, 2015 Based on the advice from DAVID!!! I bought the Hobbyking 4010 820kv 'donkey' brand I bought this. It is NOT a direct replacement and CERTAINLY not the same, it's considerably larger, it can be made to fit though you will need to fly without the Cowl and redrill the holes making the holes extremely close to the edge.... Not sure how, if you made this replacement you did not notice this.... Quote Link to comment Share on other sites More sharing options...
Stevo Posted January 23, 2015 Author Share Posted January 23, 2015 That's why I've never replaced mine, just upgraded to 4 cells... Quote Link to comment Share on other sites More sharing options...
Worden Posted January 24, 2015 Share Posted January 24, 2015 It's the ST3508 Hobbyking Donkey that is exactly the same size as the original Riot motor, seems to have about the same power too on a 12x6. Quote Link to comment Share on other sites More sharing options...
