Sabre Flyer Posted May 16, 2008 Share Posted May 16, 2008 Hi have a problem with a servo...it is the right aileron....the servo bounces around neutral before settling down. it is a new futaba3001 and was working fine before i put the model away a few months before finding time to complete. Is it a faulty servo? anyone had this problem before?Cheers Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 16, 2008 Share Posted May 16, 2008 sounds like a duffer - probably the pot not quite centering the output shaft. try another servo if you can, if the problem disappears its the servo . Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 16, 2008 Share Posted May 16, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted May 17, 2008 Share Posted May 17, 2008 just thrown away two servos that had started jittering around neutral. The biggest problem is that they can upset the power supply voltage causing the other servos to join in the jiggling, then your battery is flat in no time. For the price of a budget servo against possible loss of a model, bin it. Quote Link to comment Share on other sites More sharing options...
Sabre Flyer Posted May 21, 2008 Author Share Posted May 21, 2008 I agree with everyone...will throw it....funny thing is i wiggled servo lead and extension and the prob disappeared....will replace all as don't want the prob to reappear in the air.can't think how a dodgy lead could cause the bouncing around centre when the stick is returned to neutral? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 21, 2008 Share Posted May 21, 2008 Well it could have been that as the servo was hunting for centre, the motor and gears are obviously moving, causing small vibrations which in turn could be triggering an intermittent connection in the leads / plugs you mentioned, which then feeds back causing the servo to keep hunting and so it goes...Still, its all somewhat academic now, as you have decided, rightly, to ditch the servo and extension leads. One reason I never use servo extension leads, it merely introduces another PPOF - I hard wire any extensions needed. Quote Link to comment Share on other sites More sharing options...
