David Rivers Posted January 12, 2015 Share Posted January 12, 2015 I am building A Herr Engineering Fokker D-VII. I got this kit part built from a friend and the propeller is missing together with the bearing and prop shaft. Can anyone suggest a UK supplier for the parts. My local model shop could not oblige. SIG Mnf in USA can supply but with large p and p cost. Quote Link to comment Share on other sites More sharing options...
Robin Etherton Posted January 12, 2015 Share Posted January 12, 2015 Have you tried sams models? Robin👍👍👍👍👍👍 Quote Link to comment Share on other sites More sharing options...
Monz Posted January 12, 2015 Share Posted January 12, 2015 Yup, SAMS will supply. Nose bearing (C10 for just the bearing or C73 down the bottom of the page for a bearing, shaft and washers.): **LINK** Or D2 for standalone prop shafts (best get a few as spares, or bend your own) here: **LINK** And, for the prop, E5 for the 9.5" plastic prop, standalone, or E132 which has a prop, adjustable bearing, shaft, all ready to go, here: **LINK** And get some lube while you're at it if you don't already have some, top of the page here: **LINK** Shout if you need a hand, I've got a build thread of the same kit : http://www.modelflying.co.uk/forums/postings.asp?th=100156 Edited By Monz on 12/01/2015 15:23:34 Quote Link to comment Share on other sites More sharing options...
David Rivers Posted January 16, 2015 Author Share Posted January 16, 2015 Thanks v much for the info. Will give SAMs a try. I like the finish on your Herr plane, how did you achieve it? I am just going to cover with tissue and dope. Quote Link to comment Share on other sites More sharing options...
Monz Posted January 16, 2015 Share Posted January 16, 2015 No prob David. I used laser printed tissue finished with ezedope (which is horrible stuff, don't buy it). Standard tissue and dope is perfect. Just pin down the various bits while the dope dries to prevent warps, or use non shrinking dope (banana oil). Quote Link to comment Share on other sites More sharing options...
David Rivers Posted January 22, 2015 Author Share Posted January 22, 2015 I'm thinking of using lite span with balsaloc. Have you ever used it? Quote Link to comment Share on other sites More sharing options...
Monz Posted January 22, 2015 Share Posted January 22, 2015 Posted by David Rivers on 22/01/2015 10:27:14: I'm thinking of using lite span with balsaloc. Have you ever used it? I haven't, so can't really offer advice on it. Quote Link to comment Share on other sites More sharing options...
John Muir Posted January 22, 2015 Share Posted January 22, 2015 I've used Litespan. It is easy enough to use and more puncture resistant than tissue but imparts very little rigidity to the structure. I'd say tissue and dope would be by far the best choice for a small open frame model. If you can be bothered researching it, tissue over mylar might give the best of both worlds, but I've never used it myself. Quote Link to comment Share on other sites More sharing options...
David Rivers Posted January 22, 2015 Author Share Posted January 22, 2015 Thanks for the info. What worries me about dope and tissue is that it can warp the structure. Perhaps using thinned dope would reduce this? Quote Link to comment Share on other sites More sharing options...
John Muir Posted January 22, 2015 Share Posted January 22, 2015 Absolutely. I used it diluted 50/50. As Monz said earlier, just pin parts down while they dry or use non shrinking dope once the tissue is good and taut. I've only really used my old stash of Modelspan and that can be tightened quite nicely by applying it damp or misting it with water once it's stuck to the frame. I don't know if this is as effective with currently available tissues. I like using tissue, the pong of dope takes me back. Quote Link to comment Share on other sites More sharing options...
