Keith Evans 3 Posted March 16, 2015 Share Posted March 16, 2015 As you see I'm still getting the hang of things with these photos This project started to be formed in my mind about four years ago with a chance discussion with another club member about whether or not one could adjust the centre of gravity of a model when in flight . Over my holiday periods I take a sketch book with me to jot down any odd thoughts that come to mind that I want to capture .It was here that "Shifty "was born . Why "Shifty " well for two reasons , 1 I wanted to shift things about . 2 I was going to use as my basis a Sky 40 and the outline wing rib spacing of a Super 60 . The requirements for Shifty were to have all the following possibilities using just one wing . Moving the CofG in flight Tail dragger / trike under carriage . Bolted /Banded on wing. High /low wing configuration . Flaps . Straight /Dihedral wing Shifty Mk1 had a simple rod actuated weight in a tube arrangement for the balance control directly off a long servo arm ,and only had a banded on wing . Mk 2 had a push pull balance control system via a winch servo arrangement together with bolted on wings ---- rough landings showed the limitations of the rubber bands and the damage that could result from the inertia of the weight . I test flew the mk2 version successfully last year in the high wing ,dihedral ,trike configuration .I only had to try out the moving c of g function when due to pilot error it went in !!!! The wing was fine and the fuselage was repairable . However during other holidays Mk 3 was dreamed up .This will to have all of the above features but with a mid wing position also .I'm a few weeks from completing this . To get all the controls I wanted I also had to get to grips with a Futaba 14sg Tx and to get to this stage , learn how to insert photos into a thread ,so here goes . These are some shots of Shifty in its many configurations . Quote Link to comment Share on other sites More sharing options...
