Servo screws etc
Reading through the Modelfixings page about their servo screws and fixings, they say they supply grommets, but for using with their screws to fix cowls etc.
They specifically do not recommend using grommets on servos. I've never heard this before, and surely all servos are designed to use grommets (apart from miniature servos).
How would you fix them?
Not recommend grommets on servo screws? No never heard of that - ever. Perhaps it should read do not use cowl fixing grommets on servos?
I always put the grommets in,and then the eyelets, followed by these screws and I've never had a problem, I've used Futaba, JR, Savox....
Perhaps id should say We do not recommend these grommets for securing servos.?
Edited By Stevo on 12/04/2015 16:29:26
Edited By Stevo on 12/04/2015 16:29:37
I always use the Modelfixings socket head screws. As is intended, I use the grommets supplied with the servos but replace the standard servo screws with socket head. Have done for the last ten years. I've converted all my fixings to socket head (Allen Key) type.
For cowls, canopies etc I use the 'O' rings that Modelfixings supply.
