Fingerless Posted May 20, 2015 Share Posted May 20, 2015 I replaced a servo on the 200 with one I had lying about, not a bad fit, works ok but gets very hot, there not the e flight servos, ones I got from hobbyking, there analogue I think, are the e flight ones digital? Has anyone used metal gear servos on the blade 200 yet, the plastic ones are not very robust, thanks for reading. Every servo i try gets far too hot, no idea why there getting so hot, they seem to be vibrating all the time dont know why. Quote Link to comment Share on other sites More sharing options...
Pete B Posted May 20, 2015 Share Posted May 20, 2015 Here is the spec for the supplied servos, AFAICS. They are analogue but quite fast at .10/60deg. Are your replacements identical in spec? I think that, with a heli, it's certainly best to use the same servo for the cyclic functions, as response may vary between brands. Perhaps a Blade owner can help? Pete Quote Link to comment Share on other sites More sharing options...
Fingerless Posted May 20, 2015 Author Share Posted May 20, 2015 Thanks for that i was just hoping to save some money using some servos i have about the house i guess i will have to buy the E Flight ones at £9 each, the ones i tried where cheap ones from Hobbking. Quote Link to comment Share on other sites More sharing options...
