Servo problem with Blade 200 srx
Fingerless
I replaced a servo on the 200 with one I had lying about, not a bad fit, works ok but gets very hot, there not the e flight servos, ones I got from hobbyking, there analogue I think, are the e flight ones digital?
Has anyone used metal gear servos on the blade 200 yet, the plastic ones are not very robust, thanks for reading. Every servo i try gets far too hot, no idea why there getting so hot, they seem to be vibrating all the time dont know why.
Here is the spec for the supplied servos, AFAICS. They are analogue but quite fast at .10/60deg. Are your replacements identical in spec? I think that, with a heli, it's certainly best to use the same servo for the cyclic functions, as response may vary between brands.
Perhaps a Blade owner can help?
Pete
