Wot4 Mk3 Wing Puzzle
Scruffmeister
I've just joined the wings on my Wot4 Mk3 - and something is puzzling me...!! Have I messed this one up badly, is it normal!?
My building board it perfectly flat. When I lay the wings inverted on the board, the entire trailing edge both wings tip-to-root lies flat on the board as shown and there is no visible gap under the entire length of the wing:
However, when I put the wing upright and put a weight on one tip, the other tip clearly rises. Is this dihedral expected in a Wot4 Mk3 as I wasn't expecting it based on how carefully I laid up the wing inverted for gluing!
Cheers.
Posted by Simon Ward 2 on 25/06/2015 20:26:25:
Hi Scruffmeister,
just checked my Wot 4 Mk3 wing and it's perfectly flat on the top surface.
The wing panels do taper, root to tip, which is giving you this effect.
Here's mine, sorry for the wonky pic.
Simon.
Wot 4 Mk3 wing.
Is that a copper coloured covering i see? Or red?
Your into cycling then?
Hello KingKade,
The covering is Profilm's Chrome Red, which I happened to come across in Steve Webb's models one afternoon.
Looks great when the sun's out!!
Here's a pic:
Wot 4 Mk3
I try and get a bit of cycling in when I get the chance, the age old problem of too many hobbies and not enough free time!
Simon.
