Braddock, VC Posted October 12, 2018 Share Posted October 12, 2018 FWIW its all up weight, dry, is 5.5 Kg or 12 lb 2 oz near enough. Edited By Braddock, VC on 12/10/2018 20:59:43 Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 12, 2018 Share Posted October 12, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted October 13, 2018 Share Posted October 13, 2018 PV, It's better on the model than in a box under the work bench I guess. There was a balsa one that stevo made but the engine wouldn't fit in there without a great deal of butchery. I fitted a pilot, wish I hadn't , he's done nothing but moan about the visibility out the office so I mounted him off centre which shut him up for a bit. Now he thinks the plane looks lopsided and when am I going to fit a windscreen. The windscreen is in the pipeline as are some decals. I mislaid my adaptor for my airbrush so the decals are going to be vinyl ho hum. Given up on the lopsided-ness Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted September 25, 2019 Share Posted September 25, 2019 Due, in part, to a deadstick from the hitherto trusty ngh 25 plane landed out in the very rough grass and thistles that border our strip. During the landing the u/c dug in and was torn out but this sudden stop caused the model to cartwheel and the resultant whiplash caused all the longerons to fracture. I've agonised for ages on the best form of repair and have bought 5 x 1 metre lengths of carbon fibre 6mm square tube to replace the broken longerons, I'm also going to fit torsion bar wire u/c in the wing centre section, but lack the facilities to bend the wire needed so I've drawn up a pattern and am taking it to a local engineering company to do the bizzo. The pix around here show the fuse end of the damage, I'll completely replace the wooden structure aka oil rig with a carbon fibre one, cutting out the stubs from the front end to bond the carbon tubes in. Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted September 26, 2019 Share Posted September 26, 2019 CF tubes arrived today, so out into the fresh air and cut out the old stubs of balsa from the front half of the wreck and cut the tailplane/rudder lump off the remains of the back. Fortunately the front end has plenty of support for the longerons as you will be able to see from the attached pix. Finish for today, will glue the cf longerons in tomorrow after cutting them to length. Quote Link to comment Share on other sites More sharing options...
