WLtoys V636 Skylark with a 808 Key Fob cam
Simon Chaddock
Although a dedicated fixed wing flyer I was given a Wltoys V636 Skylark to play with.
V636 Skylark
Quite a remarkable 'toy' and a good demonstration of the wonders of micro electronics and all done on a 800mAh 1s.
A YouTube video showed a Skylark could lift an 808 cam but adding 16.2g to a 100g quad takes its toll on the performance and duration.
Now the case of an 808 is quite substantial. It actually weighs as much as the contents!
So how about a Depron case instead?
V636 Depron 808 cam
The same size as the original but with a flat top and bottom and it now weighs only 8.3g. wink 2
Of course its nothing like a proper stabilised FPV set up but then it didn't cost anything like it either!
It is amazing how 'wobbly' the Skylark is descending when compared to a climb. Presumably the result of the prop blades going in and out of stall conditions.
Edited By Simon Chaddock on 17/08/2015 17:14:32
