Simon Chaddock Posted July 2, 2008 Share Posted July 2, 2008 Just a point about pushy props and bearings. The prop thrust on the engine will be reversed so any motor (electric or i.c.) with ball bearings should be no problem but a plain bearing engine (older i.c.) might not be designed to take reverse prop thrust. Quote Link to comment Share on other sites More sharing options...
Alistair Taylor Posted July 3, 2008 Share Posted July 3, 2008 Spot on SimonSome manufacturers of IC engines )and electric motors come to think of it) put a thin steel thrust washer between the prop driver and crankcase. This reduces the wear you would otherwise get when the aluminium prop driver is pushed against the aluminium crankcase if the engine is run in pusher mode; as is the case with cox babe bee engines, which will generate a grey-black aluminium paste around the crankcase/prop driver until the wear is such that the crankshaft hits the reed valve holder. The higher performance cox tee dees came with a thrust washer I believe which avoided this.AlistairT Quote Link to comment Share on other sites More sharing options...
