winchweight Posted June 28, 2008 Share Posted June 28, 2008 Hi guys. I am trying to use my DX7 with my eFlite Sea Fury. The gear uses two servos which are installed as per the book. The book goes on to say, use a servo reversing Y lead to link the two servos to the same channel (else one wheel goes up and one goes down), or use a spare channel and mix them on your radio. I have one servo in the gear channel, and one in Aux2. How can I tie them together so that when I select the gear down, both travel together? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted June 28, 2008 Share Posted June 28, 2008 I guess you need to set ( in one of the "free" mixes ) gear as master, and aux2 as slave - then just reverse the channel throw direction on the relevant ones, and bingo. Quote Link to comment Share on other sites More sharing options...
winchweight Posted June 28, 2008 Author Share Posted June 28, 2008 Cracked it thanks mate. I had a bit of trouble getting one of the legs to lock down, but by using offset and then travel, I was able to sort it all.Cheers, Shaun Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted June 29, 2008 Share Posted June 29, 2008 Quote Link to comment Share on other sites More sharing options...
